Door seal is leaking
Nibbib
Post by Nibbib »
So I'm tw is leaking on the passenger side by where the window is curved and I pulled the seal off and looked at it it seems perfect also I'm sure my drain plug for my sunroof on same the same side is plugged would that cause the leak for the door seal? Any help would be great
Re: Door seal is leaking
If you know the sun roof drain is plugged, I'd start with that and see if unplugging it resolves the leak you're seeing.
Nibbib
Post by Nibbib »
And the best way to get to the drains is pulling the head liner right
I don't have any direct experience, but this thread has a lot of info.
http://bbs.legacycentral.org/viewtopic.php?f=10&t=183
dscoobydoo
Post by dscoobydoo »
I actually get leaks up at the same point AND I did a sunroof re-seal. Not sure where the leak us coming from, but it seems like it has found a small hole at the top and finds its way to drip into the car.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
