vf 10 ?
wagondragon
vf 10 ?
Post by wagondragon »
Legacy Wagon Legacy Wagon 93 model I pulled off a vf 11 I have a low mile vf10 I was told it came off a Subaru it both up except for the outlet is bigger and 90 not 45 degree. Can anyone tell me if this will work if I can plum the outlet up? HGL turb HGL turbo maybe? Thanks.
Re: vf 10 ?
It should work, you'll just need to redo the turbo outlet piping.
wagondragon
Re: vf 10 ?
Thanks! I still wonder what its from.and with the 2 inch outlet instead of 1.75 will it performe better.?
Re: vf 10 ?
Does it look like it will be a direct drop in on the exhaust side? The overseas Legacy/liberty used a vf10. As for performance, if you are running higher boost, it will be better. If you're just running stock boost levels, it probably won't make a big difference, and actually could cause slower spool times.
