multiple codes 11, 22, 24, 31, 44, 45, 49 swap ej22t help!!!
WagonMafia
Post by WagonMafia »
Like it says those are the codes thrown currently. I belive I've got the mechanical and vaccuum leaks under control, and AIC dialed in, it idles just under 1krpm. I believe I've got a missing or weak ground issue. I've checked and cleaned connections all around andstill codes up the yingyang. Any hypotheses? Anyone?
WagonMafia
-Pure White 93 L Wagon converted to Turbo Wagon (almost complete)
-Pure White 92 SS parts car (doner) donated to friend
-91 Mazda miata drifto DD
http://photobucket.com/wagonmafia
Someperson
Re: multiple codes 11, 22, 24, 31, 44, 45, 49 swap ej22t hel
Post by Someperson »
so many electrical codes... check the diagrams, maybe there is a common harness that flexes and is broken in places
93 Winestone TW project
robertpaige
Post by robertpaige »
maybe they're old codes that haven't cleared? have you tried clearing them and running in d-check mode?
James614
Post by James614 »
Alternator good? Funky voltage can have similar effects as shitty grounds.
WagonMafia
Hmm, ill check the alt, was borrowed from motor to my n/a for a few years and did fine.
WagonMafia
Clear the codes, and then check the codes again to see what comes back. Also, d-check mode is a good suggestion.
sqc151
Post by sqc151 »
lots of posts all with the same issues. after researching over and over. it seems to be a couple sensors.
i will find out soon and report back.
WagonMafia
Awesome, I'm going to work on the car today, I will.also report back.
WagonMafia
WagonMafia
Working on the wagon today, the idle is getting better, and throttle response too, but only when its at operating temp. Now, I've had to ground my fp relay. But periodically, the 15a engine ignition fuse pops... Any ideas? Still all the codes too.
WagonMafia
