William , more info..- Subaru Liberty (Legacy) RS
Locked
Rod
Post by Rod »
Regards Rod, in OZ
<http://www.autospeed.com/> Return to Home Page
<http://www.autospeed.com/search.html> Search | <http://www.autospeed.com/contact.html> Contact Us | <http://www.autospeed.com/adenquiries.html> Advertising
<http://www.autospeed.com/site/autospeed ... spacer.gif>
<http://ad.au.doubleclick.net/jump/Autos ... =981142364?>
<http://www.autospeed.com/previous.html> Issues Select an Issue Issue 115 Issue 114 Issue 113 Issue 112 Issue 111 Issue 110 Issue 109 Issue 108 Issue 107 Issue 106 Issue 105 Issue 104 Issue 103 Issue 102 Issue 101 Issue 100 Issue 99 Issue 98 Issue 97 Issue 96 Issue 95 Issue 94 Issue 93 Issue 92 Issue 91 Issue 90 Issue 89 Issue 88 Issue 87 Issue 86 Issue 85 Issue 84 Issue 83 Issue 82 Issue 81 Issue 80 Issue 79 Issue 78 Issue 77 Issue 76 Issue 75 Issue 74 Issue 73 Issue 72 Issue 71 Issue 70 Issue 69 Issue 68 Issue 67 Issue 66 Issue 65 Issue 64 Issue 63 Issue 62 Issue 61 Issue 60 Issue 59 Issue 58 Issue 57 Issue 56 Issue 55 Issue 54 Issue 53 Issue 52 Issue 51 Issue 50 Issue 49 Issue 48 Issue 47 Issue 46 Issue 45 Issue 44 Issue 43 Issue 42 Issue 41 Issue 40 Issue 39 Issue 38 Issue 37 Issue 36 Issue 35 Issue 34 Issue 33 Issue 32 Issue 31 Issue 30 Issue 29 Issue 28 Issue 27 Issue 26 Issue 25 Issue 24 Issue 23 Issue 22 Issue 21 Issue 20 Issue 19 Issue 18 Issue 17 Issue 16 Issue 15 Issue 14 Issue 13 Issue 12 Issue 11 Issue 10 Issue 9 Issue 8 Issue 7 Issue 6 Issue 5 Issue 4 Issue 3 Issue 2 Issue 1
<http://www.autospeed.com/cgi-bin/autosp ... timate.cgi> Forums Select a Forum Technical - General Turbos Engine Conversions Suspension Engine Management Car Audio General Discussions Feedback AutoSpeed Shop Shootouts Parts & Car Sales The Best Sites Car simulations Jokes!
<http://www.autospeed.com/cgi-bin/browse.cgi> AutoSpeed Shop Select a Category Accessories Additives Apparel & Merchandise Books Brakes DIY Modules Electronics Intake Magazines Memorabilia Oils Seats Security Videos
<http://www.autospeed.com/join.html> Join AutoSpeed
<http://www.autospeed.com/free.html> Free Articles
<http://www.autospeed.com/previous.html> Previous Issues
<http://www.autospeed.com/S_feature/section.html> Feature Cars
<http://www.autospeed.com/S_newcartests/section.html> New Car Tests
<http://www.autospeed.com/S_technical/section.html> Tech Features
<http://www.autospeed.com/S_special/section.html> Special Features
<http://www.autospeed.com/S_readers/section.html> Readers' Cars
<http://www.autospeed.com/S_performance/section.html> Performance News
<http://www.autospeed.com/S_columns/section.html> Columns
<http://www.autospeed.com/S_preowned/section.html> Pre-Owned
<http://www.autospeed.com/S_classic/section.html> Classic
<http://www.autospeed.com/competitions.html> Competitions
<http://www.autospeed.com/cgi-bin/autosp ... timate.cgi> Discussion Forum
<http://www.autoweb.com.au/usedcars.html?src=autospeed> Used Cars
<http://www.autospeed.com/gallery/index.html> Image Gallery
<http://mail.autospeed.com> Free Email
<http://www.autospeed.com/adenquiries.html> Advertise
<http://www.autospeed.com/affiliates.html> Affiliate Program
<https://www.autospeed.com/members/renewals.html> Member Renewals
<http://www.autospeed.com/members/letters.html> Email the Editor
<http://www.autospeed.com/about.html> About Us
<http://www.autospeed.com/> Home Page
Subscribe
Advertisement
<http://www.autospeed.com/cgi-bin/clkthr ... gory%3D573>
<http://www.autospeed.com/site/autospeed ... =981142364> <http://www.autospeed.com/site/autospeed ... spacer.gif> <http://www.autospeed.com/site/autospeed ... spacer.gif> <http://www.autospeed.com/site/autospeed ... spacer.gif>
Pre-Owned Performance
<http://www.autospeed.com/image.html?A=0 ... =%2Fimages> Click for larger image
Pre-Owned Performance - Subaru Liberty (Legacy) RS
A scorching performer, the Liberty RS is now the best value 1990s performance car on the market!
Member Options
<http://www.autospeed.com/site/autospeed ... dot5x5.gif> Download PDF <http://www.autospeed.com/members/article0098.pdf> Version
<http://www.autospeed.com/site/autospeed ... dot5x5.gif> Printer <http://www.autospeed.com/members/printit.html?A=0098> Friendly Version
By Michael Knowling
Page 1 of 4
Click on pics for larger images
Prior to the Liberty (Legacy) RS turbo, Subaru Australia had never enjoyed the experience of distributing a genuine performance car. Of course, there had been the 4WD turbo RX and Vortex, but neither could crack 10 seconds for the 0-100km/h sprint - although they were very reliable. The RS was the gun version of the first Liberty series released in 1988 and discontinued in 1994. Badged as a Liberty in Australia, the car is elsewhere known as the Legacy. The RS (Rally Sport) model was aimed squarely at world rallying, with many of its components and concepts carried over to the dominating Impreza WRX.
Chassis
Set up as the high performance car in the Subaru line-up, the RS is quite firmly sprung in comparison to the naturally aspirated models. However, it does retain the hereditary suspension layout consisting of MacPherson struts at each corner, and front and rear sway bars (although all of these were higher-rate). Combined with the constant all-wheel-drive, the car is close to being completely foolproof in its handling. The rear differential uses a limited slip centre, the front diff is open, and there is also a front-to-rear LSD which varies its split depending on available grip. The large four wheel disc braking performance was okay back when the RS was released but the arrangement can give problems when the car is modified. Anti-lock brakes were an option on the RS and usually found on cars also fitted with a sunroof.
Available as either a sedan or wagon, the styling of the car is nothing too wild - a "Q-car" as it was often described. To avoid corrosion, 78% of the body weight was galvanised, while PVC, corrosion resistant wax and seals are used in other design areas. All RSs sport exclusive alloy wheels, bonnet scoop, driving lights, and black skirts all 'round.
1 | 2 <http://www.autospeed.com/C_articles/A_0 ... ticle.html> | 3 <http://www.autospeed.com/C_articles/A_0 ... ticle.html> | 4 <http://www.autospeed.com/C_articles/A_0 ... ticle.html> | Next <http://www.autospeed.com/C_articles/A_0 ... ticle.html> >>
Search Articles AutoSpeed Shop
Search
Other AutoSpeed Sites
Australia <http://www.autospeed.com.au> | Singapore <http://www.autospeed.com.sg> | New Zealand <http://www.autospeed.co.nz>
Copyright © 1998 - 2001 Web Publications Pty Limited All Rights Reserved
<http://www.autospeed.com/site/autospeed/spacers/w.gif>
<http://www.autospeed.com/site/autospeed ... abel_l.gif> Vote to Win! <http://www.autospeed.com/site/autospeed ... abel_r.gif>
Question: Which one of these do you reckon will go out of fashion quickest?
huge exhaust tips
fake carbon fibre overlays
WRX-style bonnet scoops
OTT subwoofers
Lancer Evo-style rear wings
Only one vote permitted per reader per poll.
Vote and enter the draw to win a free AutoSpeed membership, or an extra 12 months on your current membership, each week.
<http://www.autospeed.com/site/autospeed ... abel_l.gif> Join Autospeed <http://www.autospeed.com/site/autospeed ... abel_r.gif>
<http://www.autospeed.com/join.html?loc=col>
What you get:
<http://www.autospeed.com/site/autospeed ... dot5x5.gif> 8 articles every week. That's 400 new articles a year.
<http://www.autospeed.com/site/autospeed ... dot5x5.gif> Immediate access to 812 previous articles.
<http://www.autospeed.com/site/autospeed ... dot5x5.gif> Direct email access to Editorial staff for technical enquiries.
<http://www.autospeed.com/site/autospeed ... dot5x5.gif> Download PDF articles for offline viewing.
What it costs:
2 years: $59.40 $US30.87
1 year: $33.00 $US17.15
6 months: $19.80 $US10.29
Monthly *: $3.85 $US2.00
* Minimum 6 months
<http://www.autospeed.com/join.html?loc=col> Click here to join!
<http://www.autospeed.com/site/autospeed ... abel_l.gif> Now Available Online <http://www.autospeed.com/site/autospeed ... abel_r.gif>
Free delivery
within Australia for orders over $50!
<http://www.autospeed.com/cgi-bin/browse ... tegory=505> Subaru Impreza - Performance Car of the Decade
Special Bonus: Receive a 3 month AutoSpeed Membership Gift Voucher when you purchase this product!
Free delivery
<http://www.autospeed.com/cgi-bin/browse ... tegory=505> 21st Century Performance
Special Bonus: Receive a 6 month AutoSpeed Membership Gift Voucher when you purchase this product!
<http://www.autospeed.com/cgi-bin/adck.c ... 0201030306>
Locked
