Wtb: ej22t crank and cam sensors
Putting a 22t back in my ss need cam and crank sensors.
•94SS full cage 2.2 hybrid build with 04 2.5i heads,JIC coilovers,jdm 4pots,vlsd,jdm TD05 16g ,top mount IC,950 injectors,running ms3x em
•91ss ej22t 110k,rebuilt heads,new seals,delta220 cams,td04,wrx top mount,wrx flywheel,wrx trans
•92L drift project h6 rwd
Re: Wtb: ej22t crank and cam sensors
ive got both. the crank sensor i have is from a later year, but has a plug and a few inches of wiring, all you have to do is wire it up to your harness. I wired my car up for the later year cam sensor.
http://bbs.legacycentral.org/viewtopic. ... s+for+sale
