Gold Mine!!!
Parts and services from sanctioned vendors and businesses.
crawlerdan
Vendor
Vendor
Gold Mine!!!
Post by crawlerdan »
i am selling of a selection of goodies. these parts are as described. im not bullshitting anything, there are no secrets, you get what you pay for, no more, no less
i accept pay pal. please add 3% for thier stupid ass fees. i will ship anything listed, on your dime unless noted other wise. i had a serious accident 7 weeks ago, need to pay some hospital and life flight bills
everything located in sw montana
1991 legacy n/a 4wd 5 speed trans 121k, needs shifter bushings
1991 legacy 4.11 rear diff, perfect
dohc 2.5 catless y-pipe
BRAND NEW, NEVER USED vf-39 sti tirbo. never installed, never out of shrink wrap
brand new, never install SOHC heads, bare, as in no valves or cams
set of DOHC turbo 2.5 heads, wrx, or sti, im not sure. they have 22k on them
set on SOHC heads, complete, n/a with 44k
factory 2004 service manual complete
2004 sohc tensioner , pully, idlers, and timing belt, brand new in packaging- will fit a ton of stuff
oem 2.5 sohc headgaskets, new
oem engine gasket and seal kit. valve seals, gaskets up the wazoo
oil pressure switch, oem new in box
2004 intake manifolds, with throttle bodies, sensors, coil, everything- i have 4
complete 2.5 sohc, 2004 outback, pan to top complete, needs to be decked and shaved, headgaskets done . has 66k miles
piles of pistons, pullys, rods, cams, all from sohc 2.5
another set of complete 2.5 sohc heads, good shape. 68k miles
a/c and alt brackets everywhere
2.5 sohc short block, pin hole leak in casting
2.5 short block, very very minor piston slap when cold
set of 2006 legacy 2.5GT headlights with projectors
COMPLETE 2000 forester wiring harness, and ecu, 2k miles
another set of sohc 2.5 heads, 17k miles
BRAND NEW IN BOX tribeca 3pc front grill set for the limited with mesh
1990 5 speed 4wd drive shaft
BRAND NEW IN BOX 2006 wrx intercooler, never even out of its wrapping
2005 STI EJ257 Short block, 17k, no KNOWN issues, warranty repair
2005 STI EJ257 Short block 12k, no known issues. nitrided crankshaft, upgraded bearings.
2008 3.6r block, no crank or pistons, bare block, brand new, never been out of its box. has a knick in 1 part, top of deck, om HG surface, could EASILY be polished out
2007 2.5 n/a short block, 42k, unknown history
1989 XT6 Recarro look alike seats
1989 XT6 mirrors in pearl white
legacy mass air meters, 4 of them with boxes
1991 legacy ls grill, very nice
XT6 alternator
1998 outback a/c compressors, have two and lines
1998 outback dohc intake manifolds with sensors, throttle bodies, etc, have two
set of nice 97k mile ej22 sohc heads, of a 1990 or 1991
xt6 dash pods, black and grey, worked
set of 205/75/14 i pike studdedf snow, mounted to steel suby wheels, balanced. 1150 miles
set of 4 all terrain m-s 195/75/14 on legacy alloy wheels, 2373 miles balanced, warranty, bla bla bla
set of 1996 outback/legacy headlights, plus a third for a spare
a ton of other little things
PLEASE CONTACT ME VIA EMAIL. crawlerdan@hotmail.com
Re: Gold Mine!!!
Post by SILINC3R »
Sorry to hear about this. At least you are able to type so that is a good sign.
crawlerdan
Vendor
Vendor
Re: Gold Mine!!!
thanks man- i suffered 3rd degree burns on 30% of my body, shop explosion. bad!
Re: Gold Mine!!!
Post by SILINC3R »
Sent you an email
Re: Gold Mine!!!
Damn! Sorry to hear that, and hope you are recovering.
crawlerdan
Vendor
Vendor
Re: Gold Mine!!!
bump
lucas
Re: Gold Mine!!!
Post by lucas »
where are you located?
crawlerdan
Vendor
Vendor
Re: Gold Mine!!!
montana
crawlerdan
Vendor
Vendor
Re: Gold Mine!!!
bump- still have a ton of stuff
Someperson
Re: Gold Mine!!!
Post by Someperson »
vf39? price? which maf? metal hitachi? price?
crawlerdan
Vendor
Vendor
Re: Gold Mine!!!
vf39 sold, i have maf off of stock early 90s legacies, some are aluminum, some plastic, 40.00 ea
jyrine
Re: Gold Mine!!!
Post by jyrine »
If the STI short blocks are still available I'm interested.
