Connection Between Side mirrors and ac?
Elcapitan
Post by Elcapitan »
Hey guys,
I have a JDM legacy with power mirrors, roof and auto ac (climate control?). Sometimes the power mirrors will not work (folding or adjusting), then they will randomly start to function again. I always suspected that it was the switch and was lazily looking for a replacement. However, I happened to notice the other day that when the mirrors aren't working, the ac won't work either. This probably means that it is not a switch problem. What I'm wondering is how the two systems are interconnected and how I could go about diagnosing this.
MY 91 legacy RS (Erin)
Re: Connection Between Side mirrors and ac?
My best recommendation would be to download the factory manual for the 92 Liberty (probably closest I have to the JDM model). With that you should be able to look at the electrical diagrams and trace how the two systems are connected.
Section 6 is the wiring book.
http://www.main.experiencetherave.com/s ... SM_-_FULL/
Elcapitan
Post by Elcapitan »
Thanx Josh. Will look at it and get back if I need any more help or help interpreting it. By the way, I had asked for your help with the steering rack repair kit. The dealer got back to me and said they have it in stock :-D I appreciate your help on that as well. Thanx (Sorry for digressing)
You're welcome for the help!
