93 diff noise
wagondragon
93 diff noise
Post by wagondragon »
Spor Sport Wagon J 22t automatic. My front diff. Makes a bad screeching noise when I accelerate firm to hard the transmission shift excellent. Is it very difficult to separate the front diff from the transmission can just replace it?
Re: 93 diff noise
Have you checked the front diff fluid? The dipstick for the front diff fluid is on the passenger side of the trans.
As for replacing the diff, yeah it's pretty involved. The entire trans would need to be dropped and the two sections separated.
wagondragon
Re: 93 diff noise
Yes I've changed it. It's been making the noise for a year now . Has gotten worse.I got the tranny pull. Was wondering how hard it is to separate the two Kinda thinking it might be the torque converter. PSw
Someperson
Re: 93 diff noise
Post by Someperson »
I have a TC that works, $30 + shipping, posting my TW partout thread tonight
93 Winestone TW project
Re: 93 diff noise
You have to pull the torque converter shaft out, and then you may be able to remove the differential section. I've never tried to disassemble the trans/diff so I'm not sure.
