04 forester xt tien monoflex coilovers on 91 ss ?
				sleepinsuby
Anyone know if these will fit my ss? Buddy if mines parting his 04xt and goving me a hella deal on them. I'd love to get the coilovers. Only thing Iv found so far searching is stock xt struts on a Impreza for lift. I want to slam.
							•94SS full cage 2.2 hybrid build with 04 2.5i heads,JIC coilovers,jdm 4pots,vlsd,jdm TD05 16g ,top mount IC,950 injectors,running ms3x em
•91ss ej22t 110k,rebuilt heads,new seals,delta220 cams,td04,wrx top mount,wrx flywheel,wrx trans
•92L drift project h6 rwd
Re: 04 forester xt tien monoflex coilovers on 91 ss ?
The fronts will bolt in but the rears wont.
				sleepinsuby
Do you know if you can swap ss rear tophats ?
It might. If it doesn't fit properly, your rest will clunk .all the time. See if those are compatible with gc8 impreza - because if so then you could just put those top hats on the rears.
