need to clean inside of TMIC blown HG sludge dripping out.
Front, Top, Air, Water.
dillonr92
Post by dillonr92 »
I got a 06 tmic the guy blew his head gaskets amd i found out later the top mount had the milky water/oil sludge in it can i take the y pipe and bpv off and use a hose to wash the inside out? Or other suggestions. i figure if i can id probaly wanna let it dry for like a week just to make sure all the waters out. Please help i wamt to install but dont wamt to harm my engine. . Also maybe a link for the bpv adapter plates and the correct samco silicone y piping kit. I have the stock vf11.
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
robertpaige
Re: need to clean inside of TMIC blown HG sludge dripping ou
Post by robertpaige »
Not sure about washing out the IC so i'll let someone else verify, but here ya go for the link.
http://www.ebay.com/itm/WRX-Type-H-RFL- ... 5af08934d9
Brake cleaner works well. You want to use a clorinated brake cleaner that does NOT have petroleum distillates in it. If you can't find one, a non-clorinated brake cleaner will work.
dillonr92
Post by dillonr92 »
Should i flush out with water after that?
As long as it doesn't have petroleum distillates, it should dry clean. You may need to go through an entire can and do it a couple times to rinse it out.
If you want, you can use a degreaser and water afterwards if you think it still is a little slimey. Use a shop vac to suck air through the intercooler to help it dry. If you can hook up the hose to the exhaust side, it'll blow warm air through to help it dry.
Someperson
Post by Someperson »
y not dawn? works the balls... rinse it out a bunch of times then shop vac. if there's some residue from the soap then rinse and dry again
93 Winestone TW project
That would work too I guess. I like brake cleaner :)
Someperson
Trichlorethane is so carcinogenic it's retarded... I only use it when its absolutely necessary...
matt00rs25
Post by matt00rs25 »
Gas!
It's just another thing to give me cancer....
lucas
Post by lucas »
maybe try a radiator cleaning place? kinda the same principle and you could always blow it out with air or bake it try
1993 legacy ss "Shela"
