my 5spd transmission has fallin.
Posted: Tue Apr 23, 2013 3:59 am
so finally after years of abuse with close to 400hp, my n/a 5spd finally broke
coming off the freeway, stopped at the light. turned left once green. driving easy, shifted to second and then floored it once fully engaged. got to about 19 - 20psi not even full power. 4,500 rpm's ripped all the teeth right off the gear.
2 blown transmissions, time for number 3. WRX gear set with 5k miles on rebuild.
lets see how this one holds up.....
