Subaru TD04 turbo interchangable with other TD04 turbos?
Re: Subaru TD04 turbo interchangable with other TD04 turbos?
I don't know the answer bug if no-one else does, I would call a reputable turbo outfit such as Blouch to see what they say. I know Blouch does the 19t wheel upgrade on 02-05 WRX turbos.
Yeah I wouldn't know either. I think it might, but couldn't say for sure.
short_round
Post by short_round »
Thank you guys for the help, I emailed Blouch Turbo and shopping.kinugawaturbo.com and I'll hopefully get a response back soon. And I'll report back.
DougFresh
Post by DougFresh »
There are so many TD04 turbos produced; I believe as long as it is an IHI turbo the parts should be interchangeable. blouch just installs a better compressor wheel (I think).
PoorManzImpreza
Post by PoorManzImpreza »
Just to clarify, a TD04 turbine is a MHI ie Mitsubishi wheel, TD04L-13T and TD05-16G describe more fully a Mitsubishi turbo. TD04L is the turbine wheel in most USDM wrx turbochargers and 13t is the compressor wheel. There are so many combinations both stock and machined to fit upgrades for Mitsubishi turbos, especially if one is starting with a TD05 Turbine..
IHI is another turbo manufacturer and must not be confused with any Mitsubishi turbo as no parts interchange between the two..
Sorry if yall know all of that already,
HTH,
Kaz
DougFresh
Post by DougFresh »
^ thanks for clarifying.
add that to my knowledge bank now haha
