Mazda Ht18s-2s, Will it work?
94Turbro
Post by 94Turbro »
As the title suggests im wondering if a Ht18s-2s off of a JDM RX7 S5 TurboII will "fit" on my EJ22t, without taking supporting mods into consideration would it work?
My friend is Basically giving it to me and id love the oppurtunity to get away from my wheezy old TD04
1994 Legacy SS: TD04, FMIC, Daily baby hauler/ Hoon cart.
Re: Mazda Ht18s-2s, Will it work?
I would assume the exhaust mounting flanges, not to mention the compressor inlet & outlet is going to be different. The simple answer is no it wouldn't work without a lot of fab work to make all the connections fit. At that point, you could have easily bought the proper fitting turbo.
94Turbro
Post by 94Turbro »
Thanks Josh. You always put things so simply.
You're welcome.
