Strering wheel "wobble"
Someperson
Post by Someperson »
Spun my fwd daily in the snow, replaced the tires and it still feels like unbalanced tires at upwards of 55mph. Think its wheel bearings? Hit the snowbank sideways at around 20 wheel fully turned towards it...
93 Winestone TW project
Someperson
Re: Strering wheel "wobble"
Gets worse under some load
Do you notice the shaking/wobble in the steering wheel, in the seat, or "all over"?
Someperson
All over, thinking it could be control arms and/ or bearings
Someperson
Nvm just wheel and occasionally the brakes
rallyak
Post by rallyak »
Did you change rims also or just tires? Might also be a bent hub, I don't think the bearing or control arm would do that. I've also been wrong before.
Charles
Someperson
You think the steelies could be bent? Or the actual hub bent bc of the drift? Lol
rallyak
Post by rallyak »
I've bent one of my rims in a snow bank and had no visual damage.
Charles
Someperson
They've been balanced though?
rallyak
Post by rallyak »
It can still balance but the rim would still move back and forth. Mine was bent 1/4 inch and balanced perfect but still wobbled.
Charles
Someperson
Ugh... Pita... At least it isn't that bad...
rallyak
Post by rallyak »
You can rotate the tire to the back. Then your steering wheel won't wobble.
Charles
Someperson
Lol true
Someperson
I think i have a damn flat spot on one of my tires lol... I had only changed the pass tire and i was rolling along and one side was dipping down about 1/8" lol... Fml i'm a failure lolol
