Exterior Trim
Rembly
Exterior Trim
Post by Rembly »
hey guys, I'm planning on painting the trim above my windows because its chipping, any suggestions on paint? I'm pretty sure the trim is plastic. I want it to look semi uniform all around without painting the non-chipped trim.
see here
Re: Exterior Trim
Its metal. I was thinking of painting mine too but I believe on the lower part is chipping and that's flat black so maybe ill plasti-dip it.
rallyak
Re: Exterior Trim
Post by rallyak »
The trim is stainless and was never prepped for paint at the factory, that's why almost all of these are flaking. I've painted the trim on my two cars, first stripping the paint with stripper then scotch bright with red pad and putting down self etching primer and painted them black.
90 and 91s also had a semi gloss or flat black on the lower portion of the trim.
Charles
Re: Exterior Trim
I may strip all mine this summer and do a good professional paint job hut its doubtful since I'm so damn busy all the tome. No time for subsrus anymore :(
Re: Exterior Trim
Post by SILINC3R »
anybody thought of just doing a vinyl or sticker over it? thats what i am thinking
BiNiaRiS
Re: Exterior Trim
Post by BiNiaRiS »
Mike were almost completely silver. I plastidipped them black. Looks awesome.
Rembly
Re: Exterior Trim
Post by Rembly »
im going to go with engine enamel after i strip paint and sand, sound okay?
Ghost
Re: Exterior Trim
Post by Ghost »
How are you guys planning to deal with the rubber on the trim edges? Is your stuff still in good shape?
Rembly
Re: Exterior Trim
Post by Rembly »
Mine is in okay shape but i want to cover the chrome with black and was planning on using bumper coating.
goderd
Re: Exterior Trim
Post by goderd »
Does anyone know of a good write up, or any tricks with removing all the trim from our BC's? I am going to paint the car, and I would like to repaint the trim as well, but seperately. I don't want to be snapping clips or bending things etc.!
92 Sport 5MT
Re: Exterior Trim
You need the metal (not plastic they bend and are crap) trim removal tools to get behind the interior trim and pop them off carefully. Its your best bet to minimizing broken tabs but you'll still break some since they're so old.
