I need some wheel help!
How big of wheels and tires can i go on my 92 legacy sport awd without having to modify to make it not rub lol
Re: I need some wheel help!
I run 205/55/16 on WRX wheels, you can go bigger though.
Charles
215 is the biggest you can go from what i hear
93 Winestone TW project
I have 04 STI struts and 205/40 ZR17 and i do not rub unless i have all my tools in the trunk.
I rock 205/60/15 with no rubs ever
If you have FWD you will rub in rear with 215/45/17
215/45/17 is what I found to be the largest.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Thanks guys!
so if i run 205/50 17s it wont rub on my strut tower eather?
When I got 225s (225/50-16 +53) I had to roll the fenders a bit. I was on sti struts which provide more clearance in that direction.
what year of sti struts would work on my 92 legacy? would any wrx struts work and have the same clearance either? did u roll the back fendors out to?
