VSS 1
Posted: Thu May 30, 2013 4:13 am
by turbo970
does any one have a pic of the VSS 1 or at least a part number. the one that the dealer order was for a 95 yet their catalog said it would fit my 92 :(
Re: VSS 1
Posted: Thu May 30, 2013 6:41 pm
From what I can tell in the parts book, the older transmissions had a separate sensor, while the newer transmissions had it integrated into the trans harness. The split happen in the 92 model year. If your car has a manufacture date of Feb 1992 I believe it should have the separate sensor.
The part # for the separate sensor is 31937AA040. Additionally, there is an o-ring on the sensor that I'd recommend replacing, it's part # is 806912140.
Re: VSS 1
Posted: Thu May 30, 2013 9:48 pm
by turbo970
mine was built on 11 or 12 of 91 and thanks josh.
just called the local subie dealer and its no longer available
Re: VSS 1
Posted: Thu May 30, 2013 11:20 pm
Well I would think you could use the new harness you bought, but you'd have to swap everything vs. just the VSS.
Try seeing if www.subarugenuineparts.com has the VSS available.
Re: VSS 1
Posted: Fri May 31, 2013 1:15 am
by turbo970
the web site says they have one but i'll have to call and make sure in the am
Re: VSS 1
Posted: Fri May 31, 2013 6:42 pm
by turbo970
no go threw there josh. gotta track down a used one
Re: VSS 1
Posted: Fri May 31, 2013 7:16 pm
So why won't the harness you bought work?
Re: VSS 1
Posted: Fri May 31, 2013 7:30 pm
by turbo970
the shop said my car is set up for the single vss. and to get that newer harness to work would cost 400 in labor
Re: VSS 1
Posted: Fri May 31, 2013 7:31 pm
Well that sucks. I guess my suggestion would be to search for a used trans prior to 92 that has the same VSS setup.
Re: VSS 1
Posted: Fri May 31, 2013 7:46 pm
by turbo970
i'm looking and the shop owner is looking. he wants me driving my car not keep it at his shop lol
