VSS 1
Re: VSS 1
From what I can tell in the parts book, the older transmissions had a separate sensor, while the newer transmissions had it integrated into the trans harness. The split happen in the 92 model year. If your car has a manufacture date of Feb 1992 I believe it should have the separate sensor.
The part # for the separate sensor is 31937AA040. Additionally, there is an o-ring on the sensor that I'd recommend replacing, it's part # is 806912140.
Re: VSS 1
Well I would think you could use the new harness you bought, but you'd have to swap everything vs. just the VSS.
Try seeing if www.subarugenuineparts.com has the VSS available.
Re: VSS 1
So why won't the harness you bought work?
Re: VSS 1
Well that sucks. I guess my suggestion would be to search for a used trans prior to 92 that has the same VSS setup.
