Clutch Upgrade Verification
92ColoradoTurbo
Post by 92ColoradoTurbo »
So since I'm bound to get my engine rebuilt/replaced, I thought I'd go ahead and upgrade the clutch since mine was starting to slip a bit when it was cold.
So I've done some light digging in the forums and from what I've read, I need an 02-04 WRX flywheel, clutch, and pressure plate.
I'm planning on racing it quite a bit so I want the clutch to last, and I also am saving up for more upgrades in the future (vf39 setup).
I just want a good clutch that can handle launches with my current setup (td04, tmic, etc. = ~200whp) therefore, do I want a stock exedy WRX clutch set or stage 1? Mind you, I'm really bad when it comes to drivetrain know-how...
A couple comments to point me in the right directions would be awesome, thanks.
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
Re: Clutch Upgrade Verification
Yes, if you get an 02-05 WRX flywheel, clutch, & pressure plate it'll work.
The one thing to note is that with a "beefier" clutch you put more strain on the transmission. So a stage 1 will provide more shock to the drivetrain than say a stock clutch.
