Power steering pump is screeching, how long will it last?
rallyak
Post by rallyak »
I'm in the middle of my shift and my wife's power steering pump sounds like a metal on metal with out any lube. At higher rpm's the noise is not so bad but at idle its a very loud grinding sound.
I have another pump but this car will be on the road for at least the next 30 hours before I can change it.
Has any one had this happen?
Charles
Re: Power steering pump is screeching, how long will it last
Has it got fluid?
rallyak
Post by rallyak »
Fluid full and belt tight it's definitely internal.
Charles
Someperson
Post by Someperson »
not very long
93 Winestone TW project
rallyak
Post by rallyak »
I hope it will last till I get off, she has all ready drove 700 miles this morning on it and I just sent her on another 500 mile delivery. The pump is still pumping, I just hope it doesn't seize.
Charles
James614
Post by James614 »
If there's fluid in there and it's not pissing out, I strongly doubt it will sieze.
rallyak
Post by rallyak »
Well it made another 500 miles but the gas mileage is down 3 mpg all day.
Charles
The screeching is more than likely coming from the bearing in the pump, not the actual innards of the pump. How long it lasts will depend, but I think you can drive on it for a little while longer.
rallyak
Post by rallyak »
Thanks josh for the encouragement and its still working but holy crap it loud. I'm sitting at a light and she 5 cars ahead of me and I can hear it with my windows up. It's funny watching people at the light trying to find out where the noise is coming from. Seven more hours and counting.
Charles
Someperson
i hope it holds, best of luck to you guys!
rallyak
Post by rallyak »
It made it,1600 miles. I'm not touching it tonight I'm too tired, I am going to be in a coma for the next 12 hours.
Charles
rallyak
Post by rallyak »
I changed the pump and inspected the old one and the front bearing was toast. I had metal shaving all over the engine but still able to drive it. Looks like I just need a bearing and have a good pump again.
Charles
Check out my thread here on how to rebuild a psteering pump. I've got info there about the bearing and what you need.
http://bbs.legacycentral.org/viewtopic.php?f=11&t=24143
