Okay here's my issue I'm going to be running kyb gr-2/excel-g shocks for a 2000 rs I have 03-07 wrx tein lowering springs and I have a good set of 90-91 front and rear top hats.
So here is what gets weird my issue is the front top hats don't match up to the springs... Now the rears work fine.
And it was to my understanding that almost every single subaru from 90-07 had the same front top hat so wouldn't that make the top hats all the same as well.
It could just be me not getting it set right or some or maybe the top hats from legacys don't work with wrx springs...
Just some help might be nice lol
						I have an issue lol
Re: I have an issue lol
I don't know if the top hats are all the same, but if they aren't you could just get the proper top hat and use your existing mount.
Yea I could but I don't really want to spend 160 on new ones from subaru
You don't have an issue, just the wrong top hats to match up to those Impreza springs.  Get some used top hats for an Impreza from a j/y, or NASIOC, etc.  They will be good and you won't have to spend the money on new ones.
http://i1346.photobucket.com/albums/p69 ... b9019d.jpg
for example, maybe.
http://forums.nasioc.com/forums/showthr ... ?t=2515206
for example, maybe.
Okay now that I have everything for the right year wrx spring perches for the top in the front but when I try boling everything together the springs are still loose and don't sit right on the tein springs but when putting the springs on a 99legacy gt strut and set the perch on it, it sits perfect so what I'm saying is the perch when spring is on the gr-2 it doesn't tighten up ( I can still move spring enough where I will not mount it) and it doesn't have prober surface contact...
Are you saying that the springs are still loose when the car is jacked up?  Are these lowering springs?  Mine Whitelines are kind of like that.  They have a little bit of play in them.
You need to take a minute and go over what you're writing.  Its almost unreadable.  If you want others to help you please take the time to make it understandable and use punctuation.  It sounds like you're saying with the car up in the air and the wheels off the ground the springs are loose.  This is because they're lowering springs which are shorter than stock springs and the struts are not designed for springs that short.  You can still use them as long as you're not jumping your car.  I put stock sti struts and springs on my legacy and had the same problem.
Yea sorry I was really frustrated with it lol. And yes they are lowering springs and I figured they wouldn't compress till the car was all the way on the ground.
And I'll post up pics up when it's all installed
