Mods List:
Engine:EJ22t
JDM TD05-16g
USDM STI 525cc injectors
Custom parallel fuel rail setup
Aeromotive A1000 Fuel Pressure Regulator w/Fuel Pressure gauge
MSD coil
Magnecor 8.5mm spark plug wires
NGK iridium IX plugs
Custom Coffee Mug intake w/cone filter and JECs MAF
06/07 WRX TMIC w/custom water sprayers
HKS SSQV BOV
3" CNT Racing Bellmouth Downpipe
Hallman Pro MBC set @18lbs
Robtuned EJ20g ecu
Walbro 255 fuel pump
Innovate LC-1 Wideband O2
Excedy Lightweight flywheel
Grimmspeed 8mm Phenolic Spacers
Sickspeed Oil catch can
WRX coolant tank
Full AC delete
Trans/Diff
02 Forester 5mt
Excedy stage 2 clutch
01 RS LSD rear diff
WRX factory short shifter
Suspension/Brakes:
06 WRX struts
02 WRX Prodrive springs
02 WRX wagon front and rear swaybars
02 WRX front 11.7" brakes
01 Legacy H6 Legacy rear 11.4" brakes
WRX aluminum rear lateral links
Interior:
05 Impreza RS all black seats
02 WRX Momo steering wheel
Airbag deletes
Glowshift Boost, Oil pressure gauge
Innovate wideband gauge
STi Aluminum shift knob
Exterior:
01 RS wheels
01 RS hood
98 Outback sport front bumper
01 RS sideskirts
01 RS crystal headlights
01 RS grille
Here are some pics, most of them were taken from my Iphone 3gs so aren't the best quality, sorry.
Here is the car when I bought it
The Interior was pretty gross but it cleaned up pretty nice
Finally getting into the garage to strip down for the swap
New engine in
Intercooler Y pipe
Wiring up the OBD I ecu with the orignal OBD II harness
I plan to add a lot more details on the wiring job and the other small details that may help someone in the future with similar swaps.
