Yet another issue
Nibbib
Yet another issue
Post by Nibbib »
Okay I posted about my issue with installing my kyb shocks and tein springs well it went on the car perfect but now ABS light is on and it isn't on right when I start it but when I slowly come to a stop I feel the breaks slip and then the light comes on and stays on.
Breaks didn't have this issue before and it doesn't feel like the breaks are going out I can still stop fine if anyone has had this issue and you fixed it please help me out it would be great
matt00rs25
Re: Yet another issue
Post by matt00rs25 »
Mine did the same thing when I put my coil overs on. Abs light doesn't come until you start to move. I hate abs so I don't bother to fix it. Prob messed up a wire or the sensor
Nibbib
Post by Nibbib »
Okay
BoostedSubie
Post by BoostedSubie »
I would check the ABS module for codes, I think there is a diagnostic plug under the dash on the driver's side or you can check it at the ABS module which has a LED light that will flash the code. I have never done this so you may want to do a search on it to get more info on how to check it.
93 Black Legacy SS
93 Legacy
97 Outback- EJ25D/22e frankenmotor
97 Green Outback
97 Red Legacy GT
98 Silver Legacy GT- Pikes Peak build, built EJ22t/205, GT3076r
99 Black Legacy GT wagon
rallyak
Post by rallyak »
The ABS module is under passenger side seat and you will see a flap in the carpet. That's where you will find the LED flashing the codes.
Charles
Nibbib
Post by Nibbib »
Okay I'll check it when I get home does car need to be running or in the on position and will it do the same as the check engine like when it flashes the code?
Here are the instructions for the ABS code retrieval.
http://www.main.experiencetherave.com/s ... bsdiag.jpg
What year is your Legacy? If it has the newer 2E ABS system, it'll be a little different.
http://www.main.experiencetherave.com/s ... ostics.gif
Nibbib
Post by Nibbib »
93 touring wagon
You've probably got the 2E, but I'd start by trying to read the codes at the ABS ECU.
Nibbib
Post by Nibbib »
Ok
