Air Conditioning Conundrum.
xise
Post by xise »
So I was getting all set to re-install a previously deleted AC system, bought a new receiver/dryer and took my relocated coolant tank an stuffed it back to the factory location for now. Installed the AC compressor and the lines to the condenser, and I realized the compressor -> Condenser line does not fit the topfeed style compressor...:( So remove the compressor and bracket for the other style compressor I have. The suction line now fits fine but the evaporator to compressor line doesn't fit!! WTF....so I have an incomplete setup either way :smt013
So what I am asking is if anyone has the top feed style compressor discharge line, the thin one that goes from the compressor to the condenser.
The other option is to get the thicker suction line from the firewall to the compressor, but that would require me to modify the electrical connector and hop that the switch engages the clutch because the electrical connectors are different.
I could take some pictures if I am confusing anyone.
Re: Air Conditioning Conundrum.
I think you're going to have to try and mix and match to get things to fit. Personally, modifying the electrical sounds easier to me, but I may not be picturing things properly....
