http://www.ebay.com/itm/EXEDY-CLUTCH-PR ... 3787862%26
or
http://www.ebay.com/itm/EXEDY-CLUTCH-RA ... 78&vxp=mtr
Which one is better?
92ColoradoTurbo
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
Re: Which one is better?
As far as I can tell the clutches are the same, it's just a choice between a 9lbs and a 13lbs flywheel. Personally I'd go with the heavier flywheel if you have ANY traffic, as a 9lbs one would be brutal to drive then.
