N/A to turbo swap with Rob tune wiring
turbo wagon
Post by turbo wagon »
93 N/A legacy wagon, building Ej22t with rob tune.
I am looking to verify what I think I need to do for this swap.
1. Add wiring to wagon as if I was just doing the N/A to Turbo swap then,
2. Add the specific wiring for the rob tune ( follow instructions for depinning and 4 to 2 convert)
3. Start car and drive off into sunset (with launch control of course)
Derek
93 legacy wagon 5speed -Ej22t swap
92 SVX
86 vanagon with an SVX swap
01 outback the lactation-station-wagon
Re: N/A to turbo swap with Rob tune wiring
That sounds right. Then troubleshoot why the car isn't running right cause sensors, wiring or grounds are bad. It's a lot of work, but I'd imagine the results will be well worth it. :)
