right so on to the serious stuff, I'm gathering knowledge for my ej22T build. and like the rest of my subaru I'm balling on a budget. so i started with the theme of hand me downs or left overs from other builds build. ei: gd coilovers that no one wanted to buy, wrx intercooler, td04, things that are an upgrade for my subaru but are stock or no really wanted on newer ones.
and that brings me to my engine. i have an ej22T bone stock, whats the best way to build a reliable engine using parts from other engines? i know that is a very vague question, but I have a very vague goal in mind. i basically want the most power out of what i can find locally. if i had to put numbers to my goal in mind 300+-whp a lot of low in grunt, high revving, while not exploding every time i drive it.
so far from some searches and stealing ideas from other peoples builds. a rough plan is 25D heads, cams, thicker head gaskets, and then i run out of knowledge.
-Ian
