transmission help needed asap
keithmoilanen
Post by keithmoilanen »
My transMission Decided to eat my dipstick. Might have to rebuild. Wrx tranny in my 91 well should be lol. Any body help? In vancouver. Can some one take a look ?
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
Re: transmission help needed asap
Did your dipstick top come off?
keithmoilanen
Chew up some gears neeed to rebuild swapped the tranny already.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
keithmoilanen
Update, broke second gear drive and driven are missing teeth. Got the shafts out but need to press off the gears. Anyone done this before near Vancouver. Don't want to mess it up. And I dont have a press.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
TurnNburn
Post by TurnNburn »
im sure there are some machine shops around you that would press a few gears for pretty cheap. It cost me $20 a gear to do mine before I had a press. a bit steep in my opinion but I didn't have any other choice.
1990 NA 2.2 Open Light rally car
keithmoilanen
Finally had time to try and get this car running again but now the transmission won't shift with the engine on. Fork and throw out bearing seem to be moving but clutch is not releasing allowing for a shift into gear. It shifts fine without engine on.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
keithmoilanen
Transmission finally is working! Now I am having engine issues, I am unable to press throttle down to where I get over a couple lbs of boost and the engine begans to die. Any ideas? I went over vacuum lines and they seem fine.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Any codes in the ECU if you do the active diagnostic with the green diagnostic connectors?
It also may be helpful if you start a new thread in the electrical forum.
keithmoilanen
Codes are really hard for me to read. But I tidy up the hose lines and no she is getting all the boost/power as before!
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
