sedan rear light bar gaskets
dafrompa
Post by dafrompa »
i have a leak coming from the rear light bar that is on the trunk lid itself. i see when i take it off their are two rub gasket that go around the light holes. woundering if their is an eazy fix for this or where to find these gaskets?
Re: sedan rear light bar gaskets
Are you talking about the rear spoiler?
You could try getting new gaskets or just cut some new gaskets out of a sheet of rubber gasket material. Use the old gaskets as a template.
Is water leaking into the trunk?
dafrompa
Post by dafrompa »
i am talking about the center light that's in between the two tail lights. i see their is a rub like gasket around both light sockets. i am geting water in my trunk
Apex3
Post by Apex3 »
That isn't a light, it's just a trim piece, and there's no gasket in there. If you're getting water in it is likely from the tail lights or the trunk gasket.
EDIT: Whoops! Don't listen to me.
James614
Post by James614 »
There's parking lights in there on the facelift models. I can't remember how it was sealed though.
The gasket part # is 84940AA070. The part # is the same for both sides, so you'll need two.
Like I mentioned in this post, you can d/l the parts book from me with all the part #'s.
dafrompa
Post by dafrompa »
thank man that's what i was looking for
You're welcome.
