93 Legacy sedan FWD flywheel and clutch questions
vtsportscar
Post by vtsportscar »
Hi everyone,
After searching I could not seem to find the answers I needed. I have a 93 legacy sedan that I'm swapping my EJ22T into and also converting it from FWD AUTO to FWD MANUAL. I'm running into conflicting information on several parts of this tranny conversion so I would like to clarify:
-will my lightweight ACT flywheel meant for 1998 Impreza AWD 2.2 fit properly with FWD application?
-what clutch can I use for a cable driven FWD?
-will it hold stock power from a EJ22T?
I'm so close to having everything and these are the last questions I've had trouble answering definitively. I have found one person who used a 98 RS flywheel and pressure plate and disc with his EJ22T FWD swap and says it works great. But I'm curious if that's the only combo that works and why? Please Help! Thank you!
Jeremy
Vehicles:
White 1993 Subaru Legacy L Sedan w/ EJ22T/6spd/R180/Td04/AWIC & much more - Autox & ice racer
Black 2005 Forester XT Premium 5spd - fiancé’s daily
Pear White 2001 Infiniti G20T 5spd - daily driver
Re: 93 Legacy sedan FWD flywheel and clutch questions
Pretty much any 5spd flywheel will work. If you want to stay with the cable driven setup then you just need to look for a clutch setup that works with the push style clutch/pressure plate.
The ACT flywheel you have should work fine.
