Parts installed with swap:
Rear main seal(set in flush)
Metal oil separator plate(bolted and rtd'd)
Input shaft seal(we set it in flush with surface)
Interior tranny filter and new drain pan gasket
All fluid drain/refills(trans, oil, front diff)
Once we finally got everything back together it shifted smooth and perfect! The car felt alive again. There were only two problems I noticed right off the bat.
1. When shifting into reverse or first gear or even downshifting(pretty much any heavy load on the tranny) I'd feel a shudder/extremely loud creak under the passenger floorboard side. Like the tranny wanting to break free or hit the chassis of the car where its mounted.
Josh and a couple others have suggested its the trans rear mount, I'm swapping my old ones in since it never did it before and will report back if this fixes it! I will also make sure everything else is still tight.
2. This is the more serious one that is mind boggling me!! I have always had minor leaks/seaps before the swap, usually oil from rear main going out and the plate on back of block passenger side... Since the swap and rear main seal/plate install I haven't noticed any oil drips, BUT atf has been dripping like a mofo. At first it was only a drip a minute coming off the jock cup looking bracket bolted to the front crossmember/behind oil pan. I figured it was prolly just overflow breathing out the hoses or ps seepage....
Well now its dripping from 3-6 diff spots including down the front diff, the crossmember, the metal ps lines, etc. Also at the rate of a few drops a minute, quite noticeable over night and who knows how much drips while driving
Symptoms I've noticed from the last week(as I've seen more atf drop) the trans acting up:
-slipping into 3rd when in D or shifting the gears manually.
-put into D and start to drive nice and easy and it wont shift up...just keeps climbing rpm until it reaches 4-5k and just slip hard till I let off
-trans shifting not as crisp/sloppy delay
The above reasons are why I'm thinking the trans is leaking but again like I said, all levels are fine! Any suggestions please throw em out, I've recently switched jobs so in between working a lot of hours that prohibit me getting underneath for a better look.
I'm thinking of adding half qt or so to the trans to see if that helps. I mean it shifted way better right after we swapped it in and that was two weeks ago ish of drips as I've mentioned.
3. Now this third problem arised roughly a week and a half after we swapped, I was checking fluids and noticed the front diff dip stick dry! We put in 1.2 qts or whatever the fsm called for when we did the swap and reused the crush washer for the drain bolt, it must've slowly dripped out and I caught it at the right time so I filled it back up and going to install the new oem crush washer on Monday, I'm constantly checking that fluid as well and it is still full! Idk if that running dry though has had any effect on my trans acting up or if it didn't at all and I saved it... Hopefully the latter
Sorry this post is so long but I wanted to include as much information as possible.
