Good +5v source inside the cab?
free5ty1e
Post by free5ty1e »
Anyone know off hand of a good place to tap +5v inside the cab?
I would imagine the ecu has at least one...but does it run anywhere in the cab or just to sensors under the hood...?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
-Chris
91SS 4EAT stock, 200k mi
free5ty1e
Re: Good +5v source inside the cab?
Post by free5ty1e »
Never mind. ..bought some 5v regulators and supporting parts, along with a 3-circuit terminal block so I can wire up a nice source for +12v, +5v, and ground for all in-cab wiring.
Also found my label maker so I can leave tags on wires that dont fade immediately!
-Chris
What are you using +5v for?
Typically the ECU +5v is a reference voltage for sensors.
free5ty1e
Post by free5ty1e »
Reference voltage for fcd voltage divider, power for various 5v goodies and experimental microcontroller projects... id rather nor draw current from the ecu reference anyway.
-Chris
I agree, having a separate supply is best.
