sunroof drain tube
sunroof drain tube
while i had the car up in the air to fix the steering rack i decided to clean the drain tubes for the sun roof. well the passenger side was clogged at the very end at the mud flap. it had so much sand and dirt and leaves piled up to the tube. any ways i'm not sure how it happen but the tube fell in behind the inner fender. is it safe that way or should i drill a drain hole ?
Re: sunroof drain tube
What do you mean it fell in behind the inner fender? Can you take a pic?
The drain tube should exit behind the fender liner, but shouldn't exit inside of anything.
i got it out lol but lost the rubber grommet that it poked threw lol
