Im looking to buy a newer vehicle due to my family increasing in size... i have no idea what its worth but ive put alot of time work and dedication into my wagon i did all the work on it myself
94 RHD Legacy With
97 EJ25D DOHC Swap hg and valves done before swap about a yr ago
96 Impreza L 5 speed swap (new clutch and flywheel)
02 Wrx rims with New tires 215/50/16 about 3200miles
JDM 4 pots at front raised lettering
05 LGT rears
94 FWD SVX 1 1/16in mastercyl
B&G Lowering springs 2in front 1.75 rear
light weight crank pulley
Goodridge stainless steel brake lines
JDM glass headlights
JDM GC8 Carbon fiber strut bar
JDM Instrument Cluster 180kph
JDM OEM MOMO 4 spoke steering wheel
Turbo legacy grille
Weapon R secret weapon air intake
OBX Racing EL headers wrapped (will include stock manifold with cat)
Tomei timing belt guide
Grimspeed 8 mm thermal spacer
Full catless 2.5 in full exhaust with OBXR oval case muffler
New 10mm wrx oil pump
Has newish transmission mount and front axles less than 6k miles
Less than 500 miles ago i replaced Timing kit with the blue gates racing timing belt including turbo water pump and o2 sensor
Needs paint but its not that bad at all a few dents here and there and absolutly no rust CA car..
BADS: NO AC no heater and has a hole on carpet on drivers side
If i get an irrestiale offer i will throw in 05 Sti exhaust mainfold with up pipe
turbo legacy crossmember
td04 turbo in perfect cond
06 wrx intercooler and bpv
and legacy turbo bumber that needs a bit of work
F/S RHD 94 Legacy Wagon
No partouts or individual parts sales.
All auctions or local sales should be in the Craigslist/eBay forum
Always open to learn
Re: F/S RHD 94 Legacy Wagon
What a great build! Terrific job.
Thank you shes pretty nimble ....unfortuantly i have to sell
also i dont have pic for the current steering wheel it has
Price Set at $4500 OBO last time on here or im keeping her forever!
has sloppy shifter easy fix for most
has turbo legacy bumper as well and oem mudflaps
currently set up to pass smog but goodies will be included
