Sunroof Fuses?
Sunroof Fuses?
I've got a 90MY legacy, the switches on the sunroof are dead. I'm starting from the easiest and looking for fuses, I can't seem to find them in the interior fuse box are they tucked away somewhere else in the vehicle?
Re: Sunroof Fuses?
This is for the 92 MY, which shows the wiring setup
http://www.main.experiencetherave.com/s ... agrams.pdf
You can d/l all the wiring diagrams for the 90 below, which will include the same sunroof diagram. I don't know if there will be any difference between the 92 & 90 MY's, but I'd probalby suggest using the 90.
http://www.main.experiencetherave.com/s ... agrams.zip
