VF36 wastegate pressure = ? Anyone know?
free5ty1e
Post by free5ty1e »
As I've asked here on NASIOC, anyone know what a stock VF36's wastegate pressure would be if I use the actuator that came with it?
Seriously, as I'm getting close to installing this thing, I realize I have absolutely no idea what my minimum boost will be. It may be that I will have to adjust the actuator arm such that the wastegate is always open until I get my FMIC and Walbro installed in the '91 (once it runs again, of course)...
-Chris
91SS 4EAT stock, 200k mi
free5ty1e
Re: VF36 wastegate pressure = ? Anyone know?
Post by free5ty1e »
lol... 12.3 PSI!
......um, yeah. I'll be adjusting that wastegate arm to just straight be open until my FMIC & Walbro pump are installed. Whew! That coulda been one short-lived EJ22T!!! :oops:
-Chris
BoneIslandScooby
Post by BoneIslandScooby »
Hey, I was about to post a new thread when I saw this one. How is it that you use the VF36? What did you have to change, if anything to make it fit?
I was wondering if I might be able to use this EWG housing to convert a VF34 to twin scroll?\\
http://www.ebay.com/itm/Kinugawa-SUBARU ... d9&vxp=mtr
It seems that if you wanted to do the swap the easiest way is to get the twin scroll header, uppipe, and downpipe. if you wanted to use what you have so far, you would have to modify a wrx/ss/sti uppipe right after the header and buy all sorts of flanges and get a bunch of welding done.
the oem or aftermarket headers and other parts i listed would be much easier I believe.
This isformation is based off images i have seen online, i have never seen a twinscroll turbo personally.
BoneIslandScooby
From the pictures I've seen, it looks like the downpipe would be the same, but the uppipe would be different. If I think about it, all I'd have to change would be the uppipe. However, I don't know this for a fact.
The downpipe flange is very different.
Sent from my SGH-T889 using Tapatalk
free5ty1e
Post by free5ty1e »
Well ill just have to take photos of the piping once I get it out of storage.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
-Chris
dscoobydoo
Post by dscoobydoo »
You need to swap to an 06/07 WRX/Sti oil pan, the full header and uppipe and the downpipe. The whole exhaust system is different, and the oil pan is different because of the twist in the exhaust pipes. Its not cheap. I put this exact set-up on my 05 STI.
You might find out the VF-36 wastegate pressure on the Aussie forums
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
free5ty1e
Post by free5ty1e »
And dont forget the 1mm hole banjo bolt for the oil feed line, or you will blow the seals out in a month or so I understand.
-Chris
