dash light problem.
dash light problem.
Hey guys, I have a 1994 wagon, I am having a problem with my dash lights, specifically with the lights behind the speedometer, rev counter and the temperature. this happened after i replace the original cigarette lighter any idea what it could be?
Re: dash light problem.
Check your fuse panel located under the left side of the dash under the steering column. Fuse for the cluster lights should be labeled as "DASH ILLUM." or something similar.
