Subject line says it all.
Will the 95 Radiator fit in my 94 and is it a simple swap??
95 MT 2.2 Legacy Radiator INTO a 94 2.2 MT Legacy?????????
dawagonbus
Re: 95 MT 2.2 Legacy Radiator INTO a 94 2.2 MT Legacy?????
I think I remember reading that you can unbolt the metal strip that runs across the top of the old one and bolt it to the newer one. But I'm far from 100% on that.
Moved to engine section.
The simple answer should be yes.
This thread has more info regarding what I've found.
http://bbs.legacycentral.org/viewtopic.php?f=5&t=48162
