wagon fuel pump?
Posted: Mon Nov 11, 2013 11:05 pm
by WastingLight
so i tried searching and i couldn't find an answer to my specific question so ill ask it anyway. i have a 94 legacy wagon 2.2 non turbo, i believe the fuel pump has gone out so i need to replace it. when i called my shop he said his book quoted an hour for labor so he figures there is an access panel under the seat, is this right? and if not how much is involved in dropping the tank? any help would be greatly appreciated
Re: wagon fuel pump?
Posted: Tue Nov 12, 2013 12:11 am
by robertpaige
Yes there is an access panel under the carpet in the back hatch. 4-5 screws and the plate is off and you have access to the pump. An hour sounds about right.
Posted: Tue Nov 12, 2013 2:00 am
by WastingLight
you seriously just made my night!! thank you so much
Posted: Tue Nov 12, 2013 5:29 pm
by wtdash
Hi,
Just to clarify a little..there are the 4 Phillips screws on the access panel and another 8 - 8mm nuts to remove, plus the 3 fuel lines and electrical connector on the top of the fuel pump plate, similar to this on my Forester:
And here's the pump:
Remember! The fuel will be under pressure unless you let the car sit overnight. Search on here to relieve the pressure more quickly.
GL,
TD
