What would I need to change out if I were to put outback struts on my 90 sedan?
I plan on doing the rears first and was wondering if I'll have to change more than just the strut itself.
Thanks guys.
Parts list for outback swap
FundamentalyConfused
1999 Forester S 5MT 200,000 miles and counting.
1990 Legacy L Sedan AWD 5MT Retired at 369,471 Miles
Re: Parts list for outback swap
Has anyone gotten rear struts from an 01 outback to work?
No, and nobody will, they are completely different. You have to use 96-99 Outback struts. All that is needed is the struts, you will use your existing springs and everything. You may have to put a washer between the rear top hats and strut rod to prevent rattle/clunking, can't remember if that applies to 1st gen legacy or just impreza.
