Parts list for outback swap
Posted: Fri Nov 15, 2013 5:32 pm
by FundamentalyConfused
What would I need to change out if I were to put outback struts on my 90 sedan?
I plan on doing the rears first and was wondering if I'll have to change more than just the strut itself.
Thanks guys.
Re: Parts list for outback swap
Posted: Sat Nov 16, 2013 8:05 pm
Has anyone gotten rear struts from an 01 outback to work?
Posted: Sun Nov 17, 2013 3:01 am
by 86BRATMAN
No, and nobody will, they are completely different. You have to use 96-99 Outback struts. All that is needed is the struts, you will use your existing springs and everything. You may have to put a washer between the rear top hats and strut rod to prevent rattle/clunking, can't remember if that applies to 1st gen legacy or just impreza.
