I think I have a bad PCV leak...
Nibbib
Post by Nibbib »
So before I posted about running extremely lean under full boost well today I installed my aem tru boost gauge which I love lol. But when I was running the vacuum line to the gauge I noticed that the PVC line that goes to the driver side head was really loose so I wiggled it and I don't even think it's hooked up
Would this cause my car too run lean under load and I'm pretty sure idle high
Does anyone have pictures of the intake off and the PVC system hooked up?
Re: I think I have a bad PVC leak...
Dammit mike..
Sent from my SGH-T889 using Tapatalk
Nibbib
Post by Nibbib »
damn iphone.. auto correct lol i did look at the diagram that legacy777 wrote in the sticky just wondering if anyone would have an actual picture of it with no intake manifold.. but im pretty sure i need to replace a lot if not all of the vacuum hoses..
I'm sure if someone with an engine on a stand would be willing to snap a few pictures for you. Based off the diagram what hose are you referring to that is broken?
Nibbib
Post by Nibbib »
It would be either ten or nine in the Pcv sticky in the intake section but with out taking off my intake im sure the other side isn't hooked up since the driver side is so loose
Sorry bud I was on my phone and didn't catch the Turbo part. So my diagram wasn't too helpful. Edited and posted the correct graphic for quick reference.
Nibbib
Re: I think I have a bad PCV leak...
Post by Nibbib »
It's all good haha just really wondering if it isn't hooked up if it would cause my car to run lean under full load and run rich under deceleration?
alexandermf
Post by alexandermf »
Someone correct me if I'm wrong but I don't think that leaking has anything to do with your lean/rich issue. I'm thinking fuel delivery isn't enough psi under full load possibly. That happened with my stock fuel pump until I upgraded to walboro
Nibbib
Post by Nibbib »
I already did the walbro pump I've posted before about my issue and people have said to clean my iacv and that should fix it but I'm thinking it's just gone bad... Possibly
Nibbib
Post by Nibbib »
Found out the damn hose really isn't hooked up lol
