WET! '90 LS Wagon
Posted: Sun Dec 29, 2013 2:20 am
by virginwidow
Hi, I'm new to Subaru, CARS infact (truck person)
Gotta cool 1990 LS Wagon which was/is WET. Of course, electric gremlins follow but first order is get the WET out.
Looks like roof & windshield seals are sun/weather damaged. The roof seal running front to rear, each side, above the doors looks like somebody did a 1/2 ass job of trying to fix with mobile home sealer -- This I can fix, structural silicone (basicly, aquarium glue) which works GREAT -- cleaned real well first, prep/prime with MEK/acetone, apply with CARE - but is VERY permanent... It aint coming off I mean NOTHING cuts this stuff, if ever removed it's with pliers and scraper and TIME (oh gawd ALOT)
it's the WINDSHIELD and MOON-roof I'm leery of. .. (Things we might need to replace/repair) They both intact but the rubber-oid seals need replacing? Or??
Moon-roof works nicely but not always -- so it gots to come out to have new rubbers put in -- and the Gremlins exterminated -- how to be damn sure "they" kill the gremlins in the same shot they changes the rubbers...
Right now we're wearing FOIL duck-tape drying out... Don't want to get the silicone into anything that might have to come apart, it will "crawl" into cracks, which then become a SOLID
Anyone had and solved this?
THANK YOU
Bobby in Knoxville
Re: WET! '90 LS Wagon
Posted: Sun Dec 29, 2013 7:54 pm
by rallyak
I will bet that the sun roof is leaking which is very common on our cars. Some times all it needs is the drain tube cleaned so the water has a place to go instead of in the car. Rubbers would help also not sure if Subaru still can get them.
I had a 91 with a sun roof that I ended up tastefully siliconing it shut and that stopped the wetness in mine.
Posted: Tue Dec 31, 2013 3:36 am
by virginwidow
rallyak wrote:I will bet that the sun roof is leaking which is very common on our cars. Some times all it needs is the drain tube cleaned so the water has a place to go instead of in the car. Rubbers would help also not sure if Subaru still can get them.
I read the (REALLY GREAT) topic on sunroofs -- when we finally get a fair day or 2 here I'm going to go huntin the drain tubes (if they can be seen without dismantling the car) Couldn't get a clear idea wether those were reasonably easy to access
There was a couple very nicely detailed descriptions how to completely fix it -- seems to be within my ability / tools. if I only had a garage.
Only trouble is the pictures were gone and the website references also dead :-(
I'm fine with the "taped shut" option for now but it's too hot here in summer (SE United States) to not make use of COOL-roof -- gasoline too high to run AC.
THANKS
Bobby in TN
Posted: Thu Jan 02, 2014 11:05 pm
Bobby,
I'm assuming this is the thread you found?
http://bbs.legacycentral.org/viewtopic.php?f=10&t=183
If so, what page are the pictures you are trying to view?
