Starting Problem After Power Washing
subarulegacy
Post by subarulegacy »
my 1992 subaru legacy estate EJ16 wont start after the engine was power washed
Re: Starting Problem After Power Washing
Welcome to the BBS.
I split your topic into its own thread since your issue is likely different than the original poster of the thread you posted in.
I would suggest checking all the electrical component plugs to make sure water is not in them. Also, pull the spark plug wires off the plugs and make sure there is no water in there. A little can of compressed air for dusting helps blowing any water out of the electrical connectors.
