AWD Fuse
Posted: Mon Oct 21, 2002 2:20 am
by Fugazi
I heard if you remove the fuse for AWD, you basically get a front wheel drive car. I was thinking about trying this out, I'm kinda tired of always having perfect traction
, anyone know if this will work or if it will harm anything?
Posted: Mon Oct 21, 2002 3:39 am
You don't remove a fuse......you stick one in.
If you have an automatic....yes you can stick a fuse in the AWD fuse holder, and it will disable the AWD, and all you will have is FWD.
It will still turn the driveshaft a little....and won't make gas mileage any better though.....but ya you can put the fuse in and drive around like that.
Posted: Mon Oct 21, 2002 5:24 am
by Fugazi
My car is a stick. Would it still work?
Posted: Mon Oct 21, 2002 1:53 pm
No!
You do not have an AWD fuse holder. There's no way to disable the AWD on a manual tranny.
Posted: Mon Nov 25, 2002 8:49 pm
by magicmike
I read in a subaru manual once that you shouldn't drive with the fuse in, it is only if you need to tow the car and if doing so it shouldn't be for more than 20 or 30 miles or something like that. I may be wrong but thats what I can recall
Mike
Posted: Mon Nov 25, 2002 8:52 pm
by ciper
Well, I know for one thing that THE WHEELS MUST STILL TRAVEL AT NEAR THE SAME SPEED.
For example, putting the fwd fuse in and testing on a two wheel dyno while the rear wheels remain still does damage the center diff (just not very much).
Posted: Mon Dec 16, 2002 1:37 pm
by IggDawg
I played with that thing on my '02 Impreza TS. It was fun
. It's definitely a FWD car with that fuse in place. Spinning the wheels is no problem. In fact, it's kinda tough to avoid. We're more spoiled than most of us know. Flooring it from a stop directly into a sharp 90 degree turn is a normal thing for me. It's a little different without the AWD. My GF's Impreza L with it's mighty NA 2.2 can chirp the tires going inot second. And it's an auto
My TS had 150-ish lbft of torque at 4k or so. I can't imagine what 180 lbft of torque at 2800 would feel like with just 2 wheels. I bet launching at 3200 would feel a little different.
