antennas
lucas
antennas
Post by lucas »
any way to change the motorized antenna to a screw on type antenna? Ass clown at my local car wash didn't put down my antenna before running my car. Folded it completely over. Motorized antenna hasn't worked in years anyway.
1993 legacy ss "Shela"
lucas
Re: antennas
Post by lucas »
never mind oreillys had some cheap screw in type. switched it.
alexandermf
Re: antennas
Post by alexandermf »
How's it work?
lucas
Re: antennas
Post by lucas »
works just as good as the stock one, but now I'm torn.... whether i want to blow the old one up with tannerite or crush it with a big hammer cursing the designer for such asshatery
James614
Re: antennas
Post by James614 »
I didnt know any of the 1st gens got motorized antennas.
alexandermf
antennas
Mine and all my buddies first gens do
James614
Re: antennas
Post by James614 »
I'm happy my TW doesn't. Fixed mast FTW.
dscoobydoo
Re: antennas
Post by dscoobydoo »
you can replace the mast pretty easily
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
rallyak
Re: antennas
Post by rallyak »
Mine has duel antennas, one I use only in the winter (fixed on the roof) one in the summer ( power on the quarter).
Charles
lucas
Re: antennas
Post by lucas »
screw on type is just better. I guess you could argue less weight too but the electric one doesn't weigh much to begin with.
Re: antennas
The turbo legacies and I think the LS models had the motorized antenna.
James614
Re: antennas
Post by James614 »
Huh. Maybe my TW's was replaced at one point.
Re: antennas
Hmm.....maybe they changed things later on or maybe the wagons didn't get them.
Alphius
Re: antennas
Post by Alphius »
All TW had motorized antennas as well. James614's must have been swapped out at some point.
Easy way to tell: All manual antenna Subarus have the antenna above the driver's side window on the roof. All power antenna Subarus have the antenna on the driver's side rear quarter panel. (Applies until '99 for Legacys)
Re: antennas
I thought the wagons were on the pass side?
Sent from my SGH-T889 using Tapatalk
