swappable sensors from na to turbo
turbo wagon
Post by turbo wagon »
I am swapping a ej22t into a na ej22 93leagacy and I got one extra of each of the sensors from a na legacy and was wondering witch of the sensors would work on the turbo motor. I did notice that the iac top was different but is that interchangeable.
93 legacy wagon 5speed -Ej22t swap
92 SVX
86 vanagon with an SVX swap
01 outback the lactation-station-wagon
Re: swappable sensors from na to turbo
Everything else should swap over.
Sent from my SGH-T889 using Tapatalk
What year non-turbo legacy did you pull the sensors from?
turbo wagon
93
92 SVX
The MAF sensor won't work, but I believe everything else will be interchangable.
