how do you change bulbs in map light on 93 legacy sedan
pooh
Post by pooh »
Help..I bought a 93 with no owners manual and don't know how to change the map light bulbs. Do I remove the light switches themselves, or the whole box.. Can someone please advise...Thanks so much
Re: how do you change bulbs in map light on 93 legacy sedan
You talking about the little left and right lights by the rear view mirror? The covers pop out.
pooh
Post by pooh »
yes the little lights, but I was unsure if the little light themselves or the whole square cover.
Also, just an FYI I scanned the owner's manual for my 90 Legacy. Your 93 may be slightly different, but the main points will be the same.
http://www.main.experiencetherave.com/s ... _(PDF).zip
