torque/power split on a 4EAT
Danteandsoob
Post by Danteandsoob »
Does anyone know what the ratio is for a 1993 legacy L 4EAT is in overdrive, 1st , 2nd, and 3rd? likes, threads or specs are greatly appreciated.
- '93 Metallic Blue Legacy L, DD w/lots of mods
- '91 Mazda Miata, Autox fun car
scoobydoo94turbo
Re: torque/power split on a 4EAT
Post by scoobydoo94turbo »
If I remember correctly your Subaru Bible actually tells you (user manual) If you don't have one pm me and I will get you the specs..
05 Forester XT 2.5L Turbo DD 250,000km R.I.P
94 Legacy Turbo Touring Wagon 412,000km ) R.I.P
91 Legacy Sport Sedan 136,017km (parts car) R.I.P
04 Impreza TS Wagon 230,000km timing idler failed, being rebuilt!
94 Legacy Turbo Sedan 285,000km Mint DD
It is constantly varying depending on driving conditions, but if you're cruising down the highway it'll be about 90/10. The most it could ever be is 50/50. The amount of rear drive/lockup will primarily depend on acceleration/throttle position and front & rear wheel speed differences.
Danteandsoob
So what does the ratio look like in 1st and 2nd manual gears on an automatic? That guy never got back to me on what the specs were.
50:50 split in 1st and 2nd when you have the gear lever in those positions.
Danteandsoob
Awesome, thanks so much.
PhyrraM
Post by PhyrraM »
If you wish to verify, many multimeters have a duty cycle function. This can be used to monitor the wire that goes to the AWD solenoid (Duty cycle C?). The wiring diagram will show the wire color and position. The trans ECU is right above your left knee, so tapping the meter into the wires should be pretty easy.
100% duty cycle = 50/50 torque split
50% duty cycle = 75/25
20% duty cycle= 90/10
etc...
