front bumper crack repair?
killajamal
Post by killajamal »
I recently acquired a turbo front bumper that has a small crack. Anyone have any ideas or insight on repairing something like that?
The crack is up near the side by the blinkers. Is there an easy way to repair or work with plastic bumper material?
rallyak
Re: front bumper crack repair?
Post by rallyak »
Plastic welder, and some stainless wire mesh is how I fix them. The repair is stronger than the original bumper and not very hard. I have a welder but most people live too far for me lend a hand.
Charles
I've got buddies that use soldering irons as make shift plastic welders.
James614
Post by James614 »
I didn't know they made plastic welders. I will need to look into this.
killajamal
Thanks for all the input guys! I just grabbed some two part epoxy and bondo. I'm in the process of filling everything and sanding in between full time work and finishing my schooling. But it'll work out!
rallyak
Post by rallyak »
Bondo will not work on plastic it will break off. There is a special type of filler for plastic,
http://www.tcpglobal.com/AutoBodyDepot/ ... fgodsTgAXw
This is pretty good stuff and it feathers good and it sticks.
Charles
killajamal
You're definitely right! There are some small gouges throughout the bumper that I just slapped some bon do on. I'll look into getting some plastic filler. They didn't have any at the store earlier and I already had some bondo.
I watched a guy use a small torch and black zip ties (as the weld) and he made it work
Grayguy
Post by Grayguy »
I have a chance to pic up a "plastic stapler" that I might try out on a cracked bumper
Sent from my SAMSUNG-SGH-I537 using Tapatalk
92' SS: SOLD
